Editing roof objects
  Once a roof object has been created, there are multiple ways to edit it:
Edit some parameters from the Object Info palette.
Change roof edge shapes (such as hip or gable) using the Selection tool and the Edit Roof Settings dialog box.
Create cutouts in the roof using the Clip tool or Clip Surface command.
Reshape the roof object using the Reshape tool.
Add an accessory: attic, soffit, or fascia (Vectorworks Architect required).
